So a couple things prevented the maiden.
1. So I ran a lead off of one of the receiver batteries and used that to power the retract/brake unit. However, they still work without the lead plugged I. So they are getting power off the receiver which i was trying to avoid. Any ideas?
2. I am running a dual aileron, dual flap, and dual elevator program on the DX18 so the nosegear has to be in channel 11 on the rx but there is no way to mix it to the rudder because you can only mix the first 10 channels. ???
Thanks!
