Thats why why I was wondering if you put the black wires on different pins and gang the red on one pin, it would work. I know you can run 4 servos on a 6 pin connector By ganging all of the red wires on one pin and all of the black wires on another pin And then running each signal wire on the remaining four pins
Originally Posted by
Dansy
Doesn’t each motor might be different speed, so the gear might not be fully out or in when the output port stop?
I normally used 1 AMP 10 pins connector per side (Ail/Flap Gear/brks) like the one Ultimate jet sell, they are on digi-key website.....
