Stuka JU 87d RTF Add RX and Lipo
Stuka JU-87D Model this is a fiberglass fuselage ESM Model . assembled the wing is 80 inches one piece , Has flaps , all servos are Power HD metial gear , digital servos , 120 Amp Hv > ESC installed .Has a Scorpion S-5545-150KV Motor 22X10 Fiala Prop Makes 2600 watts with this prop on 12 Cel lipo , , You will need to install> RX and Batterys to finish , Model Has 2 Flights to Date . Thais is a pick up only in Lynchburg VA
Wing Span 80
Length 66
Weight 14.3 lbs
