RE: Inverted 2-stroke starting ideas needed.
I'm with Flyboy Dave on this procedure for getting the cyl's wet and ready for the glow igniter's. The only advice I can add is make sure you have 2 good hot igniter's and if you are using an on-board system make your own. The twist on head systems are a pain.
