Thanks so much!!! Exactly right! The pain is slightly bent but the bearing is definitely messed up as you said. I will order those up! Thanks again
Originally Posted by
dccatl
There are two bearings in the housing that support the pin for the strut, they're cheap un-shielded bearings, the balls fall out of the races with just the slightest hard landing, bet that's your problem. I replaced mine with these:
https://www.bocabearings.com/product...zz-w2-5c-15185
Rock solid now.
