RCU Forums - View Single Post - Bisson "Pitts" smoke manifold?
Old 11-01-2003 | 01:07 PM
BruceW
Default Bisson "Pitts" smoke manifold?
Any ideas on fabricating a smoke injector manifold for a Bisson Muffler. Figuring the most optimum results for massive smoke would be achieved by mist atomization. I was thinking of a small-1/8" OD brass tube. Both ends capped. With several fine holes drilled on centerline. Then braze this piece to a pressure tap fitting. Bolted on the inside of the muffler, adjacent to the exhaust inlet. Voila'-a smoke injector nozzle. Anyone done anything similar? I'd appreciate your ideas.
Using the Sullivan Skywriter pump on a OS 1.60.
Any ideas??? Thanks for your time.
BruceW
