RCU Forums - View Single Post - Dreams of a brushless M1A2 Abrams
Old 06-26-2018 | 06:26 AM
Imex-Erik's Avatar
Imex-Erik
Originally Posted by tankme
Yes I am using the OP board, but it will be paired with some Hobby King brushless ESCs. I really like the idea of using these gearboxes because they are enclosed. Should eliminate gear oil or grease flinging. I will be beefing up the lower hull also.
I think you will like it. OP has that speed limit by percentage that really helps with higher voltage stuff. The momentum and inertia settings are fun to play with as well, I bet with a brushless application it will be even better. I actually haven't done a BL tank on OP, I bet with a sensored BL motor it would be awesomely slow...
