Gluing the fuselage sides together. If the formers are square to one side of the fuselage then the other side should be also when the formers are in the notches but it is best to check all the way around. Keeping the bottom of both sides flat on the building table helps to assure that they are parallel and no twists creep in.
Reason: difficulty loading photos
