Originally Posted by
RuneG
I have the OS beltmotor and if I should move the battery futher in front I have to do some mod, I will give it some flights and see what I think.
Yester day it was to much crosswind to tell how the KE was .
Maybe I have to move the Esc up on the side in the fuse and have cabels at the back off the battery.
So you use the wing bolts for Balance point ok
It might be easier to move the elevator servo forward and use pull pull cables for the rudder.
You might add some lead weight to the nose to determine what it will take to get the C/G correct....then move equipment later and remove weight.
Let us know how how you are doing.
