RCU Forums - View Single Post - Jetcat P120 thrust level help needed
Old 07-15-2018 | 03:50 AM
ledd4u
My Feedback: (23)
Originally Posted by John Redman
Paul,
The thrust figures listed by Vinny are for the latest versions of the P120's, mainly the SX version. If your engine is indeed 14 years old and has a serial number of under 1400 I would guess it will push around 24 - 25 pounds at full tilt unless it has been fully upgraded with the new style compressor, EGV, Diffuser, Chamber. The P120's from the serial number I listed above and older were around 24 - 25 pounds of blow. At 115,000 I would guess it is pushing closer to 16 pounds.
Just what I recall from running thousands of these engines over the years on test stands, etc.
Your statement is neutral in context. Before 1400 24-25lbs. Above 1400 25-25lbs. Sounds like tax brakes. Just a little confused about the statement. I own a serial number 2455 and it’s definitely more than 25lbs. Non SX, those are simply a POS from what I read.
