RCU Forums - View Single Post - YS DZ200cdi
Thread: YS DZ200cdi
Old 07-23-2018 | 03:06 PM
  #129
drac1's Avatar
drac1
Originally Posted by bjr_93tz
Just a quick question.
Is there a trick to preventing an aluminium spinner backplate from slipping on the prop driver, or do I just need to add an extra weetbix to my cereal bowl for breakfast before bolting on the prop?? It's not coming loose as such, just slightly changing position every now and then, and slowing mangling the prop driver...
It sounds like it's no where near tight enough, if it's moving with normal flying.
Only one secret Brett. FT
Don't be afraid to reef on the spanner. Use a combo spanner with the ring end on the nut, hold the prop and pull, then pull some more. Even with a huge lean run, mine doesn't move at all.
