Hello Todd
Changing from 7.4 to 9.9 affects mostly everything to manage the extra voltage
If you are getting the low voltage reading means the battery is not capable of holding the minimum voltage during the hihg amp. draw of the start up
check how low your battery gets during a start up
Is the 10.2 v reading from the ECU or is from annother system?
