Originally Posted by
Ragz
Hello.
Recently bought an airplane from a friend that has not been flown for 4 years. Its an Avonds F15. Builts very nicely and in pristine condtion. Its got 8 doors with 6 being main doors. These are operated with UP 2 and UP 4 valves in tandem. The UP 4 being the secondary valve to keep one set of main door open when the gears are down. The other doors will close. I find that the UP 4 valve won't keep these main doors OPEN. The moment I pressurise the system, these doors will close even when the mains are down and touch the struts. I have gone through the entire plumbing and everything is connected correctly with no leaks. Basically the UP 4 is not sending a signal to EVER open the door. The UP 4 manual is only a schematic and it doesn't show how to adjust anything. That being said, this airplane was functioning perfectly when it was flown last (4 years ago). Could the UP 4 valve be jammed? I thought it was a static secondary valve with no moving parts. The UP 2 that is feeding the signal pressure is functioning perfectly. Any suggestions?
Anurag
I the UP 4 has a "slider" valve in it that is likely stuck. I have one on my Euro Sport and I believe that you can get to the slider by removing the two screws on the one end and taking out the circular "door" that the screws hold in. Then you should be able to break the slider free, lube it up a bit, and it should work fine...
Bob
