You are incorrect on your your plumbing/sequence thought process. The U.P. 4 valve operates the gear and the doors that close when the gear is down. ( Like the inner clam shell doors on a P-51 Mustang ). The U.P. 2 valve's job is the keep doors open when the gear is down.
It can be very confusing... Hope this helps...
Dan.
