RCU Forums - View Single Post - UP 2 and UP 4 valves question
Old 08-07-2018 | 02:33 AM
Ragz's Avatar
Ragz
The pressure is around 60-80 psi. As soon as I start pressurising those doors close. Are you saying if I pinch that line the air will be forced on the other side and activate the sequencer? Do I need more pressure to activate it? Usually this is the pressure I use on ground for testing.
