A stone tipped one, mostly they are in the accompanying set. One You can use in the slot without touching the opposite side. Sometime they are a bit pointed but by holding the Dremel under an angle that it will flatten more or less in the plane of the slot. But it is not very critical. Blow away with compressed air the dust that comes off.
