Hi Manchu9inf ,
are you going to use the stock plastic tamiya tracks ?
I had trouble with the tamiya sprockets meshing correctly into the tracks. A 0.15mm shim washer was required to spread the two halves of the front sprocket so the teeth would comfortably fit in the track holes.
Cheers
Afrikakorps
