Originally Posted by
kevinthoele
Kevin is the spring on the outer door standard or upgraded? Stock was not staying closed
The spring is what Skymaster put on it at the factory. It feels pretty damned strong though, If it doesn't hold the door closed I will have to come up with a different method to actuate the door since I think a spring any stronger than this one would cause gear problems.
