Originally Posted by
r ward
as far as I understand,...that's what you are doing when you register with the FAA. if I am wrong, so be it and I stand corrected. they are the ones that regulate your radios wave length an strength, aren't they ?. the way I look at it,....the pilot has to register, but his radio has to be within a certain range of frequencies to be used for r/c,....it is therefore regulated and registered.
No! The FAA does not "regulate your radios wave length an strength". The FCC does. And for systems operating on 2.4 Ghz, as most do now, there is NO FCC registration. Just buy it and use it.
