Savor Servo
I installed a Savox servo from another car I wasn't using, but I had to trim off some material from the servo mount. The normal servo mounting screws are long and when I trimmed off part of the servo mount the mounting screws on the bottom blocked the chassis screws. So, I had to use a shorter screw for the lower servo screw. The stock servo saver fit perfectly on the Savox servo.
