RCU Forums - View Single Post - 2.4 GHz and ignition interference
Old 08-22-2018 | 03:17 PM
  #37
RyanNX211's Avatar
RyanNX211
We’ve being testing different systems over the years. DSM2/X and FrSky seem the most vulnerable. Nanos work well unless you use a servo eliminating switch.
The Building Board: 2.4 Receivers and Ignition Engines
https://tinyurl.com/yav35y5k
https://tinyurl.com/yche69vz
Each manufacturer will tell you the problem is not in the receiver. Except for FrSky which admitted it was by coming out with an ignition receiver.
