Old Design in a new jacket.
why change a Well proven system for the last 15 years?.
this new Serviceable Air trap system from Digitech.
.High Flow 1500Ml/Minute
.1 tank or 2 tank connection with 6-8MM OD Festo Connection.
.6MM OD connection to your pump.
.all connections are G1/8 Festo Threaded so you can choose from more connections.
.Filling side is done with a 4MM OD Festo (M5 Threaded.
. clamps can be rotated to fit the UAT in any position , or you can leave out the clamps.
all parts can be exchanged!.
check out the test video,s and see that the airtrap still works with more then 2/3 of air introduced into this system.
Available now from Digitech and their Dealers.
available from Aeropanda.
Part 1 Air introduction into the system.
Part 2 even more Air
