RCU Forums - View Single Post - Glow plug, false reading??
Old 09-02-2018 | 04:57 PM
SACKRC
My Feedback: (7)
Default Glow plug, false reading??
My turbine took a mild dip in the water, after a wash out with kerosene and some disassembly I was able
to get it running again except for the plug ignition reading. Its a jet cat 120 se and I get no plug
error mess. , yet the glow plug does not work in ignition seq.. So when starting i use a separate battery to lite the plug direct. Naturally when I unplug the glow plug it does give error mess. Engine does start in this manor
but its work to get it running in this way. Thinking front board not working, but it does all thinks correct.
Learn RC, start sequence, & turbine will run throttle. Will back to default do anything, Or any ideas
on problem. Also when in the glow plug test menu i upped voltage too
max 3 v and it wont lite when hitting the button. Thanks Rich Barile
