Originally Posted by
sjames1
Thanks you so much man, con you please post pictures of you motor install? Id like to see how you set up the brackets with such big motors.
I’m currently not at home, so I can’t post pictures now, but I will try to remenber to as soon as I‘m back.
You can see a view of the motors on post number 270 of this thread.
I made brackets with fiberglass plates. If I remenber, wood slots for the motors are 3mm. Turbine bracket is 1mm, so I made a sandwich with 1mm fiberglass plate on each side of the motor bracket, and slide this in the wood slots.
