RE: Trim question
I agree with Dalolyn, minor engine thrust adjustments can very often greatly improve flight characteristics. If your CG is properly placed and measured incidence on wing and stab are correct, then the next obviouse adjustment is thrust line. Many of the ARF trainers are not well set up as to thrust lines and most can be greatly improved with careful adjustments.
