RE: Tx buddy cable
When you buddy box a Hitec and a Futaba, be sure to use the Hitec trainer cord and have it plugged in properly, there is a master and a slave end, both well marked. If you do not, the slave transmitter may transmit as well as the master unless you remove the crystal and battery from the slave.
