RCU Forums - View Single Post - Modify Switch Function - 14SGA
Old 09-07-2018 | 05:06 AM
gstephanos
Default 14SGA Switch
On several other airplanes with retracts, moving the same switch fully “up” retracts the gear and the servo stops running. With this airplane when the switch goes from “down” to the middle position, the gear retracts. However, if the switch moves to the full “up” position the servo runs with a grinding sound. I’m not sure how to remedy this situation.
