RCU Forums - View Single Post - Kingtech GSU dim
Old 09-08-2018 | 07:40 PM
Custmachr
Originally Posted by rhklenke
I just got my K-85G2 setup. I turned it on and everything came up OK, but the GSU screen is *very* dim. I could read it, but just barely.
Anyone know what the issue is? I'm running my RX on a 5.6V regulator and the ECU battery was 9.8 volts.
Also, the RPM reading was jummping around until I spun the turbine using the starter test. Then it was OK and read correctly. Is it normal for the RPM readings to jump around when the turbine is not spinning...
Bob
you need about 6.5 volts on receiver for ECU to function correctly.
