RE: I just re-entered the hobby...
LordLo,
I started back into this hobby the same way that you did with 15 years away. I bought a simulator cord from ebay and used the FMS simulator last winter. Simultaneously, I built a LT-40. I think you will enjoy this trainer, as it is easy to see and flies slow enough for you to learn. Excellent choice. I thought the FMS allowed me to get a good feel for the plane and how to react when it is coming at you. I mostly used the SuperCub. Once you get pretty good with the simulator, you should be able to handle your plane pretty well. I would still highly recommend finding a club member to help you with your first flights. Get an AMA card and then find someone to help you out. I just helped someone get airborne that crashed on his first attempt. I was lucky and had a successful first flight without help. Enjoy this hobby.
