RCU Forums - View Single Post - Ecu batteries
Thread: Ecu batteries
Old 09-09-2018 | 02:49 PM
sirrom
Default voltage errors
Originally Posted by Len Todd
Pacific RC has LiFe packs. So does ElectroDynamics.
In the past, I have seen both Jet Cat and Kingtech give you high voltage errors with fully charged LiFes. I personally prefer LiPo. But the new Kingtechs require LiFes. So I am stuck with them for the K-160. The good thing with this requirement is I have finally found a use for all the LiFes that I never used that came with the Jetcats. The K-160 has never given me a high voltage error either. But it did spin the bearings at 260 minutes.
This is also a problem on the JetCentral turbines also, but you can run the starter motor as if in cooling mode. This will burn off that excess voltage getting rid of the error.
Patrick
