I have searched the thread but must be blind if it's here. Looking for the setup (wiring & config) of using two Jeti 2.4 R3 receivers (Pri & BU) into the CP and only one output for both receivers from the CP to the Central Box 200 primary RX slot so that I can use the 900Mhz backup into the Central Box secondary Rx slot by-passing the CP. Is that possible?
