Originally Posted by
rskiba
I have searched the thread but must be blind if it's here. Looking for the setup (wiring & config) of using two Jeti 2.4 R3 receivers (Pri & BU) into the CP and only one output for both receivers from the CP to the Central Box 200 primary RX slot so that I can use the 900Mhz backup into the Central Box secondary Rx slot by-passing the CP. Is that possible?
This set up is pretty much exactly as you described. The details being:
Primary 2.4 receiver connected to port B
Secondary 2.4 receiver connected to port A
RX1 of the central box connected to port 6
REX 900 connected to RX2 of the central box
Also, don’t forget the additional power lead from an open servo port on the central box to the cortex pro as shown in the manual connected to port 4
Danny
