Originally Posted by
F1 Rocket
This set up is pretty much exactly as you described. The details being:
Primary 2.4 receiver connected to port B
Secondary 2.4 receiver connected to port A
RX1 of the central box connected to port 6
REX 900 connected to RX2 of the central box
Also, don’t forget the additional power lead from an open servo port on the central box to the cortex pro as shown in the manual connected to port 4
Danny
Danny,
Thanks for the reply - I have it working without the 900 Mhz now and two 2.4's. So, I think I just unplug the CP to Sec RX connection and install the 900 directly into the Central Box Sec Rx port. I already have the "extra" connection installed as well from Central Box servo port to Port 4 on the CP. In this configuration, the two 2.4 Rx's have to fail before the 900 is invoked, correct? and the Jeti Tx can still keep track of which receivers is doing the "work"?
