Originally Posted by
hk3957w
good day
I receive the CTU, follow the manual and this forum to install, I am reading in the DS24 all information coming from the CTU and kingtech 120 g2 with the LUA app can see in the device explorer also can configure the CTU from the transmitter, port configured in Exbus. but I have some doubts.
1. CTU state is 1536 with no change if move the throttle. its ok?
2. in the CTU the red light is flashing fast. its ok?
3. can I connect at the same time the kingtech GSU and the CTU?
Thanks to all and good day
Hi Yes 1536 is Trim low - turbine off all ok!
yes led should be flashing fast that is ok
yes you can connect the GSU at the same time as the CTU it makes no difference. (NOT on some Jetcat GSU!)
you can use a `Y` Lead or a "V" lead depending wich country you come from , its due to a cultural difference we can call it a V or a Y lead :-). right Cartsen?
