RCU Forums - View Single Post - Removing Carb from a Dynamite Engine
Old 09-19-2018 | 12:39 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Loosen the draw bar (“pinch bolt”) so it’s loose. Try twisting the carb clockwise to break loose, then work it both ways while pulling on it and it should come out. If the draw bar was overtightened, it will deform the carb body a little and it will bind in the bore. Twisting and pulling will remove it. Why do you say the carb isn’t working and needs replacement?
