RCU Forums - View Single Post - YS DZ200cdi
Thread: YS DZ200cdi
Old 09-20-2018 | 07:12 PM
  #167
drac1's Avatar
drac1
Originally Posted by riot3d
I use the Gator flow thru spinner on my 200 sold by F3A Unlimited, it has a lightened back plate:- https://www.f3aunlimited.com/gator-spinner-82mm-red.
However, be careful on over tightening on spinner with a lightened plate, may cause warping. If the prop is slipping, just put two spacers made out of sand paper - one between the drive washer & the back plate, & the other one between the front of the back plate & the prop - that should solve the problem.
Adrian
Hi Adrian,
I've often looked at those spinners. The only thing that has stopped me getting one, is not knowing the weight. Can you tell me how much it weighs?
Sandpaper has never been successful for me. The driver serrations just cut through it. The only real solution I think is FT
