https://www.nitrorcx.com/25c103-14-v...brushless.html
The Tacon Valor is a 1/14 scale Monster Truck. It was designed from the ground up with pure performance in mind. Performance features derived from 1/8 scale trucks and buggies have been shrunken down in size and engineered to deliver the utmost performance in a smaller monster truck package. A 2mm thick aluminum chassis serves as the base of this truck. Mounted on the front and rear is 2.5mm thick 6061-T6 anodized aluminum shock towers towering over the planetary geared fluid filled differentials. Attached to the robust towers are aluminum threaded oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of the truck over varying terrain.
This truck has an awesome power to weight ratio. Weighing in at slightly over 2 lbs, the vehicle is easily propelled by the 380 sized brushless 4500KV brushless motor. A brushless electronic speed controller delivers the current efficiently through an included 7.2v 1100mah Ni-Mh battery and charger. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the performance wheels off road knobby tires. We recommend a Gens Ace 7.4v 1800mah lithium battery for an exponential increase in power and efficiency.?
The Tacon Valor ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
With a body designed with monster truck styling and big tires, the truck handles exceptionally well on bumpy terrain and responds quickly with throttle and brake inputs while mid flight off of a jump. This truck will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end or flying over obstacles easily correcting itself landing on the perfect transition.
Features:
1. Tacon design treaded tires
2. Aluminum-capped, oil-filled, coil-over, 6061-T6 adjustable shocks
3. Front and rear metal gear differentials
4. 2.5mm 6061-T6 aluminum shock towers
5. Brushless Tacon ESC
6. 2838 4500KV brushless motor
7. 4WD shaft drivetrain
8. Adjustable mini Solar 655 servo with saver
9. Steel hinge-pins with rounded front bumper
10. Tacon receiver with 2.4GHz technology
11. 7.2V 1100mAh NiMH battery with 3.5mm gilded round connectors
12. 12mm wheel hexes
13. 2.5mm anodized aluminum rear and front kick-up chassis with dirt guards
Specifications:
Scale: 1/14 Tacon Valor Monster Truck
Length: 280mm (11in)
Width: 340mm (13.4in)
Height: 132mm (5.2in)
Wheelbase: 185mm (7.3in)
Weight: 0.90kg (1.9lbs with battery)
Tire Type: Tacon Monster Truck
Chassis: Aluminum
Motor or Engine: 380 Brushless
Steering Servo: Solar 655
Gear ratio: 8.23
Speed Control: Brushless Lipo Ready
Radio: 2.4GHz Technology
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminum, threaded, oil-filled, coil-over
Package Contents:
100% Assembled
1x 1:14 Tacon Valor Truck
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
