Originally Posted by
Flyrc67
Thanks again guys. One more question, if I may, how do you finish the interface between the glassed portion and the covered portion of the fuse. Do you just use a ffiller like bondo and sand it down to blend the surfaces, or is there some other way? Thanks in advance.
I used lightweight spackling just used my finger to spread and shape it hardly no sanding. Then I put two coats of nitrate dope on it and all the air frame. The covering bonded much better with the dope. Only bad thing is the smell.
https://sigmfg.com/products/sig-clear-nitrate-dope
