RCU Forums - View Single Post - MicroX Racing 1/24 Micro Scale Desert Monster Truck Ready to Run 2.4ghz RC Remote Con
Old 10-05-2018, 02:28 PM
yadac123
Default MicroX Racing 1/24 Micro Scale Desert Monster Truck Ready to Run 2.4ghz RC Remote Con
https://www.nitrorcx.com/68c01-24-desert-truck-24g.html
MicroX Racing introduces its smallest most compact desert monster truck to hit the market. Constructed on a molded composite chassis this truck sports an agile 4WD shaft driven drivetrain. A powerful brushed micro motor delivers tire spinning torque and speed to this already small and light weight chassis. Realistic desert monster truck styling and details keep things fun and exciting. The 1/24-scale electric RTR 4WD desert monster truck has all the features you would want in a hobby grade radio control vehicle. Proportional digital control, dedicated steering servo, high current electronic speed controller and battery. The vehicle is ready to run and comes with a rechargeable battery pack and charger. This monster truck is fully equipped to attack the track. All you need to do is take it out of the box, charge the battery and let it rip!
Features:
Shaft driven 4 wheel drive
Molded composite chassis
Coil shocks for dampening
Realistic Monster Truck Body
Ready to Run
2.4ghz Radio System
Off-Road treaded tires and wheels
Shock absorbing bumpers
Powerful motor system
Length: 165mm?
Width: 128mm
Specifications:
Length: 165mm (6.4in)
Width: 120mm (4.7in)
Height: 78mm (3.0in)
Wheelbase: 110mm (4.3in)
Ground Clearance:? 18mm (.35in)
Gear Ratio: 1:12.6
Steering bearing: Oil bearing
Wheel: 33*12mm
Gear Ratio: 1:12.6
Servo: 1.0g
ESC and Receiver: 2 in 1
Radio System: 2.4GHz
Battery: 4.8V 220mAh Ni-MH
Car Weigh: 172G
