https://www.nitrorcx.com/68c07-24-rally-blue-24g.html
MicroX Racing introduces its smallest most compact rally car to hit the market. Constructed on an molded composite chassis this truck sports an agile 4WD shaft driven drive train. A powerful brushed micro motor delivers tire spinning torque and speed to this already small and light weight chassis. Realistic rally car hatchback styling and details keep things fun and exciting. The 1/24-scale electric RTR 4WD rally car has all the features you would want in a hobby grade radio control vehicle. Proportional digital control, dedicated steering servo, high current electronic speed controller and battery. The vehicle is ready to run and comes with a rechargeable battery pack and charger. This Rally Car is fully equipped to attack the rally courses. All you need to do is take it out of the box, charge the battery and let it rip.
Features:
Shaft driven 4 wheel drive
Molded composite chassis
Coil shocks for dampening
Realistic Rally Body
Ready to Run
2.4ghz Radio System
Off-Road treaded tires and wheels
Shock absorbing bumpers
Powerful motor system
Specifications:
Length: 175mm (6.8in)
Width: 100mm (4in)
Height: 70mm (2.7in)
Wheelbase: 110mm (4.3in)
Ground Clearance: 9mm (.35in)
Steering bearing: Oil bearing
Wheel: 33*12mm
Gear Ratio: 1:12.6
Servo: 1.7g
ESC and Receiver: 2 in 1
Transmitter: 2.4G
Battery: 4.8V 220mAh Ni-MH
Car Weight: 158g
Required to Run:
4 AA Batteries for Transmitter
