If you have the push button type then check your instructions. The push button is held down instead of the toggle switch, that will put it in bind mode. The MG was moved from the toggle switch to a press button on the V2 transmitters but the bind sequence is still the same, press the button/toggle for the MG and turn on the transmitter. You should see the TX blink fast just like the video showed
Let me know if that helps! I'm pretty sure I saw an email from you too asking the same thing, I'm getting ready to answer emails right now (I'm on break picking up a work truck atm) so expect the same response in email if you were the one that sent it
Please let me know if you got any other questions!
