ORIGINAL: jglp3
My Bobcat climbs when full throttle is applied, do you shim up the front or rear of motor? It's not an excessive pitch change, but I would like get rid of it.
Do not shim it. Loosen the straps very little, then raise the nose of the turbine a small amount. IF you have a P120/80, the starter should be 1/8-1/4 above the rear of the fuse where the hole is.. Try it and adjust as needed.
