will say that I the spring does fit in the pocket and the pocket is only deep enough to retain the spring's location, it should be safe to use. however...you might want to get another spring for the other valve so that the working spring pressures are the same from valve to valve,..... widely uneven valve spring pressures make engines vibrate more than necessary.
