RCU Forums - View Single Post - Super Silly Smoke Question
Old 10-13-2018 | 12:45 PM
AAbdu
My Feedback: (18)
Default Super Silly Smoke Question
I was setting up my Halloween decorations and decided to give the old fog machine a test run. As it warmed up and started to produce fog I wondered.... Would this water based "fog fluid" be a viable option for producing smoke if I pumped it through my smoke pump then into the hot exhaust of my turbine? I like an experiment as much as the next guy but I figured I would ask to see if anyone had tried it, or had a logical reason why it wouldn't work or wouldn't work well.
I googled the product to see what is in it an this is what I got:
Typically, fog is created by vaporizing proprietary water and glycol-based
or glycerin-based fluids or through the atomization of mineral oil.
This fluid (often referred to colloquially as fog juice) vaporizes or atomizes
inside the fog machine.
I ask because there are numerous recipes for home made fog (as I am sure there is for some fluid, but more importantly because I can get it dirt cheap by the case on November 1st.
Anyone have any thoughts on if this would be worth considering or even pumping some through my turbine smoke pump. I noticed my fog machine smoke has a grey tint to it.
[img]blob:http://www.rcuniverse.com/34758499-1df5-4b79-9500-5223807e0bbe
File Type: pdf
