Here is a gold mine of information about Spektrum programming. Be aware that there really isn't any separate adjustment of servo throws on the ailerons that does not come with some issues. Lots of folks will use sub trim which isn't a good idea if there is a lot. So before you try setting throws, try to make the mechanical setup as nearly perfect as possible.
R/C Tech Tips
