The balancer is a Graupner type - so I just ran a graupner 3 cell LiFe for the ECU and used the BMS to output to 2 powerbox RX batteries through the charge jack (which gives a balanced charge). As I understand it by using the BMS with the ECU balance lead plugged into it it then gives the ECU pack a balanced charge.
