RCU Forums - View Single Post - ESM Spitfire (highly modified)
Old 10-26-2018 | 06:34 PM
JSZ's Avatar
JSZ
My Feedback: (73)
Default ESM Spitfire (highly modified)
This is the ESM Spitfire, has a glass fuse and built up wood wing. I had been flying it for one season. I decided to do something different. I stripped all the covering. Sheeted the bottom of the wing, reinforced the landing gear area with carbon fiber and glassed the wing. Completely refinished the plane with all panel lines and rivets. Wing blisters are from Yellow. Full cockpit with full body pilot. W/s was 89 but now 85 since I chose a clipped wing version. Has Sierra retracts, DLE 55ra with radio operated choke. Hitec servos, scale type tail wheel. This plane is offered without the batteries and reciever that is currently installed. The batteries are Ed-Nano A123s and Spectrum reciever. They can be left in at this price or reduced if not wanted. I also have the wing guns, I just forgot to put them on. Most of the simulated hatches on the wing are Aerofoil covered for weathering purposes. A lot of work went into this project to try to have something different for you every weekend type flyer.
JSZ is offline
