Jetcat Titan and P120SX thrust per RPM
I thought at one time there was a chart that gave thrust per rpm on a number of engines?
Here is my situation.
Earlier this year I bought a GJC F18 that will be my winter project. In searching for an engine I ended up with a beautiful F86 with a jetcat titan in it that has been turned way down. The F86 only needs 18 - 20lbs thrust.
I had a kingtech K80 that I planned to put in the F86 so that the titan could be used in the F18.
Long story short, the 86 has a BVM style bypass and I came across a fantastic deal on a P120SX which would drop straight into the F86 with no modification so I sold the K80 and bought the 120.
I don't want to use 30lbs thrust in the F86 though so my question is, how do you determine the amount of thrust per rpm on a 120SX as well as Titan?
sorry, still a bit long winded I guess but thanks in advance.
Reason: Auto correct strikes again!
