You can just use the throttle and that adjusts the power infinitely all my scale jets are way over powered, but you never see me flying fast! Since we have little energy compared to FS, sometimes you will need the 32lb available to drag the F-86 slowly through a climbing turn.
Since power is not linear and even tailpipes effect thrust, drop it to 121,000 if you must and try it. Titan is a JetCat P-160 so the chart that was published will have that. Least JetCat has decent thrust at moderate rpm, unlike some turbines where it’s only available in the last few thousand rpm
