...whilst talking about:
On the maiden we discovered that the nose gear did not retract completely at the first attempt. On the ground everything worked flawlessly. Don't know if the springs of the main gear cover are ajusted to strongly. Together with te air flow in flight it is probably to much for the controller.
I have got the first edition of it, the black one and there the indicated max. voltage is 8.4 V. I would have a LiIon Battery 3S with 9.9V but wouldn't like to try this without your advice as it could fry the unit...
What are your experiences with the gear?
Thank you, Daniel
